1999 Oldsmobile Cutlass changing fuel filter
1999 OLDSMOBILE CUTLASS
DARRELJUL
  • 5 POSTS
1999 Oldsmobile Cutlass 6 cyl Automatic 140000 miles
how do you pressurise the fuel system before changing the fuel filter
Oct 2, 2009 at 10:50 PM
JDL
  • 16,098 POSTS
I guess you mean de-pressurize? I use a pressure gage, aim the bleedoff hose into a container, hit the pressure bleedoff button. The pressure gage fits to the schrader valve. If you have an easy way to disconnect the pump, then just start the vehicle, let it run till it dies. Usually after the vehicle sits overnight with out the key being cycled or engine running, there isn't much pressure,but, you still need to be aware.
Oct 3, 2009 at 9:58 AM
