1998 Oldsmobile Cutlass over heating issues
REYNOLDSM
  • 1998 OLDSMOBILE CUTLASS
  • 6 CYL
  • FWD
  • 77,000 MILES
I have a 1998 olds cutlass with 77000 mi in resnt weeks the car started to over heat I have replaced the thermostat new coolent then had it tested for exsaust in the coolent it showed that there was exsaust gases in the coolent I then replaced the head gaskets and now the car runs better but still will run hot is there anything I have missed
thanks
Saturday, September 4th, 2010 AT 5:53 PM
HMAC300
  • 48,601 POSTS
If it was overheating before the head gaskets were replaced then it probably wasn't it. Best thing to do as you probably don't have any leaks is to disconnect the fans and check the radiator. Do this after it overheats and try placing your hand in different spots all over. If you feel any cold spots, then your radiator is bad. It should feel the same temp by hand all over. If you see any loose fins or greenish color ones you will need either a recore or a new one.
Saturday, September 4th, 2010 AT 7:45 PM
