firing order?
1998 OLDSMOBILE CUTLASS
123,704 MILES • 6 CYL • FWD • AUTOMATIC
ANABELL
removed heads from a 3.1 liter took spark plug wires off coil packs did not mark them and the numbers on the coil packs r not the orginal james
Nov 22, 2008 at 10:38 AM
  • 110,244 POSTS
Hi:
Standing in front of the vehicle looking at the the coil packs, there are three of them. From left to right, the first coil pack is 1 & 4, the second coil pack is 6 & 3, and the third coil pack is 2 & 5. Now still standing in front of the engine, the first three cylinders in front of the radiator are 2,4 & 6 and the last three near the firewall are 1,3 & 5.
The firing order is 1,2,3,4,5,6 if it is a 2.8 or 3.1. What you did not say is what engine it has (2.8 VIN "W" or 3.1 VIN "T")
Let me know if this helps.
Dec 11, 2008 at 8:25 AM
ZELAYA
Electrical problem
1995 Oldsmobile Cutlass 6 cyl Two Wheel Drive Automatic
Please I need the wiring order diagram for this 1995 Cutlass with 3.1 V6 engine.
Thanks in advance
Aug 1, 2020 at 5:21 AM (Merged)
JDL
  • 16,098 POSTS
https://images.2carpros.com/forum/automotive_pictures/170934_31_ciera_1.jpg
My info showed the above for a 3.1 ciera.
LDOWNER10
1994 Oldsmobile Cutlass 6 cyl Front Wheel Drive Automatic
what is the firing order for 1994 oldsmobile supreme cutlass 3.1 v6
There you go Merry Christmas
https://images.2carpros.com/forum/automotive_pictures/12900_fo_77.jpg
PISTACHIORICAN
I need to know the order of which the spark plug wires are put into the engine.
JDL
  • 16,098 POSTS
Hi, which cutlass do you have? What I looked at was cutlass ciera, 3.1L vin T
https://images.2carpros.com/forum/automotive_pictures/170934_ciera_firing_order_1.jpg
EDIEGO
I need to know what the firing order for the car is so that i can double check and make sure that its correct.
BMRFIXIT
  • 19,053 POSTS
[quote:4910738a59="ediego"]Engine problem
1986 Oldsmobile Cutlass 4 cyl Front Wheel Drive Automatic 30,000 miles
I need to know what the firing order for the car is so that i can double check and make sure that its correct.[/quote:4910738a59]
4 cyl firing order is 1 3 4 2
let me know if need more
good luck
MIKE STEEL
need firing order for 1985 olds. cutlass v6. please send firing order for distributor cap.
  • 55,423 POSTS
Hey Mike, Here is the firing order and distributor rotation diagram you requested for a v6 Gm. Let us know if you need anything else we are here to help.
https://images.2carpros.com/forum/automotive_pictures/561653_firing_order_85_38_1.jpg
THIZZLLE
i know the firing order for my car its 1,6,5,4,3,2 but i need a picture or something cause i dont know where these are like what wires is #1,6,5,4,3,2 and where is #1 wire is it the one on the left closest to the bumper or closest to the windsheild i dont know?
i replaced my distributor cap and i thought i put wires on in the right order but theres a clicking sound from it and my friend said i put the wires on wrong thats why i need to know which wire goes where
BMRFIXIT
  • 19,053 POSTS
best i can do hope that help
https://images.2carpros.com/forum/automotive_pictures/99387_olds_2.jpg
