1998 Oldsmobile Cutlass car wont sart
CHARLES LYONS
1998 Oldsmobile Cutlass 6 cyl Two Wheel Drive Automatic
i forgot to put the radiatoor resevoir cap on when i put antifreeze in it, drove away car overheated turned itself off i pulled over pushed to a parking lot it wont start
engine is turning just not catching
i have spark its getting fuel i smell gas has a small leak like a squirt burst on and off when i try to start it coming from what looks like the exhaust manifold underneath it
Oct 21, 2010 at 6:12 AM
  • 110,246 POSTS
First, you need to fix the fuel leak. That could be causing low fuel pressure. Next, are you getting a good hot blue spark?
Nov 2, 2010 at 1:11 AM
