1997 Oldsmobile Cutlass Radiator Replacement
1997 OLDSMOBILE CUTLASS
150,000 MILES • 6 CYL • FWD • AUTOMATIC
BIGGSPOT
How do I replace the radiator in my 97 Cutlass Supreme? Have never done anything like this before but can't afford the cost of someone else doing it so I'm taking a chance. Detailed instructions are greatly needed and appreciated. Thanks.
Feb 22, 2010 at 7:46 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Disconnect the negative battery cable. Drain and recycle the engine coolant. The coolant drain is located on the radiator mount. Loosen but do not remove the petcock. (Radiator support removed for photo only)
https://images.2carpros.com/forum/automotive_pictures/261618_1_130.jpg
Disconnect the upper radiator hose from the radiator. Remove the upper transaxle cooler line from the radiator. Remove the coolant surge tank hose. Detach the cooling fan electrical connections. Unfasten any lines or conduits anchored on the fan body. Remove the bolt securing the A/C line to the fan shroud near the coolant surge tank. Refer to the accompanying figure.
https://images.2carpros.com/forum/automotive_pictures/261618_2_91.jpg
Remove the fans
https://images.2carpros.com/forum/automotive_pictures/261618_3_39.jpg
Raise and safely support the front of the vehicle securely on jackstands. Remove the lower closeout panel. Remove the lower radiator hose and lower transaxle cooler line from the radiator. Plug the transaxle line and fitting Remove the bolts fastening the condenser to the front of the radiator and secure the condenser to the vehicle with wire Remove the lower radiator mounting panel. Remove the radiator from the vehicle To install: Installation is the reverse of removal
Feb 22, 2010 at 9:58 PM
