1997 Oldsmobile Cutlass radiator fan
1997 OLDSMOBILE CUTLASS
100,000 MILES • 6 CYL • FWD • AUTOMATIC
STOGYE
what is the easiest way to test the fan
Mar 9, 2010 at 9:04 AM
BLUELIGHTNIN6
  • 16,542 POSTS
turn A/C to full blast. fan should come on. if not, supply 12v power directly to fan motor. if fan comes on then check fuses and relays. if doesnt come on replace it.
Mar 9, 2010 at 9:39 AM
STOGYE
and if the a/c hasn't worked in two summers?? this tests fan but what about the sensors just cause fan works with 12 volts doesn't mean it works WHEN it should
Mar 12, 2010 at 8:55 PM
BLUELIGHTNIN6
  • 16,542 POSTS
you asked easiest way to test the fan, not the sensors... if you're wanting to test the engine coolant temp.
https://www.2carpros.com/topics/climate-control/air-conditioner
Mar 13, 2010 at 1:43 PM
