Car overheating, replaced thermostat, fans appear to be ok, no water pump leakage or other leaks, coolant ok. Any suggestions on where to go next ?
Nov 9, 2008 at 11:37 PM
✓Experienced Mechanic
Check if the radiator is clogged up, water pump functioning and could be airlock in the cooling system-If none above causing it-Get it block and pressure tested to rule out blown headgasket, cracked head or block -intake manifold gasket leak-
