1997 Oldsmobile Cutlass NO SPARK
1997 OLDSMOBILE CUTLASS
99,000 MILES • 6 CYL • FWD • AUTOMATIC
AVULLMAHN
With the key on,all fuses and relays marked "ignition" are good and hot;but nothing hot going to coils and no spark.
Mar 23, 2008 at 6:07 AM
Check the white wire at the ignition control module for power not there its coming from the computer-check also to the coil's pink wire from the ignition fuse not there pink wire has an open circuit-
Mar 23, 2008 at 7:12 AM
