1997 Oldsmobile Cutlass Cold starting problem
VERNON NEAL
Engine Mechanical problem
1997 Oldsmobile Cutlass 6 cyl Automatic 150000 miles
My car runs perfectly when starte .starts perfectly in hot weather but wont start or is hard to start in kool weather say below 80 digreas
Sep 7, 2010 at 5:25 PM
JDL
  • 16,098 POSTS
I need something more to go on? Any applicable trouble codes? To check codes, at the least, you need an obd2 code reader. When the problem occurs, use a gage and check fuel pressure, key on engine off. Some of the national brand autostores used to loan out a fuel pressure gage, if you don't have one. If temp related, sometimes a coolant temp sensor can cause an issue? I don't have enough info, at the moment?
Sep 8, 2010 at 3:21 AM
