1997 Oldsmobile Cutlass
RICE8J
  • 1997 OLDSMOBILE CUTLASS
Engine Cooling problem
1997 Oldsmobile Cutlass 6 cyl Front Wheel Drive Automatic
Heater blows cold air, passenger side floorboard is wet and it gets hot
Wednesday, January 13th, 2010 AT 1:32 PM
JDL
  • 16,098 POSTS
Welcome to the forum, if that is antifreeze in the floor, I suspect a bad heater core.
Wednesday, January 13th, 2010 AT 1:40 PM
RICE8J
That would also make the car run hot?
Wednesday, January 13th, 2010 AT 1:49 PM
JDL
  • 16,098 POSTS
Possibly on your question, and there could be two different issues. If your losing coolant, get it fixed. Does the radiator fan run ok?
Wednesday, January 13th, 2010 AT 3:18 PM
RICE8J
Fan works fine, jus moved it and its smoking and the oil is milky so I'm guessing its the head gasket right
Wednesday, January 13th, 2010 AT 3:28 PM
JDL
  • 16,098 POSTS
Some makes, have had trouble with intake gasket. That shouldn't cause coolant in the floor-board.
Thursday, January 14th, 2010 AT 10:51 AM
