Heater problem
1996 Oldsmobile Cutlass 6 cyl Two Wheel Drive Automatic
car over heats heater blows hot air then blows cold air resavor fills up and over flows
Thursday, March 19th, 2009 AT 6:18 AM
EUGENE123
MECHANIC
Your water lines have air in them to fix this problem bleed your coolant system using the bleeder valve located on the water line in the front of the motor in front of the valve cover pan
