1996 Oldsmobile Cutlass where can I put an aftermarket oil
1996 OLDSMOBILE CUTLASS
134,000 MILES • 6 CYL • FWD • AUTOMATIC
JWT767
Hey guys, do you know where I can screw in an aftermarket oil pressure sensor? It's not really a sensor, but the brass fitting, and hose that feeds a mechanical gauge?
Oct 21, 2009 at 1:43 AM
JDL
  • 16,098 POSTS
Tie in at the oil pressure sender unit, probably close to the oil filter. if you use a tee, you can probably get everything hooked-up. Also, this is your project, your responsibility. If something goes bad, you lose oil pressure and the engine seizes, tha'ts on you, not me. Goodluck
Oct 21, 2009 at 8:30 AM
JWT767
I tried that this weekend, did not get any readings on the gauge, nor did I get any readings when hooked directly to where the oil sending unit is screwed in. What's there now is actually an oil pressure switch, which turns the light on or off.
Would the pressure still be the same?
Oct 21, 2009 at 11:14 AM
JDL
  • 16,098 POSTS
That's the only place I know of, to tie in?
Oct 22, 2009 at 2:51 AM
