1996 Oldsmobile Cutlass Trouble Codes
232,000 MILES • 6 CYL • FWD • AUTOMATIC
REDNECKF150
I got 96 olds cutlass supreme 3.1 v6 auto, with newly replaced motor. Any way i let my car sit about a week b4 driving it again, and when i started it up to drive it, it wouldnt pull out with out the gas being pressed down all the way. and even then it has no power and it dont seem to shift gears either, i just tuned the motor. Well i got these check engine light codes PO753 Shift A solenoid electrical
and PO758 Shift B solenoid electrical and P1864 TCC Curcuit... Do these need to be replaced, or what????? i have checked the fuse box and the ones underneth the hood they are all good...[img:8ef8a4a1b2]http://www.2carpros.com/forum/automotive_pictures/288618_Picture_004_1.jpg[/img:8ef8a4a1b2]
Apr 21, 2010 at 12:31 PM
  • 110,251 POSTS
That is odd. The shift solenoids do just that, shift. It shouldn't cause a problem when you first pull out. Is the trans fluid full and clean?
May 20, 2010 at 1:21 AM
