1996 Oldsmobile Cutlass ticking
80,000 MILES • 6 CYL • FWD • AUTOMATIC
OLDSMOBILEDOWN
there is a ticking sound, but it is not a lifter. It sounds electrical. I pulled off plug wires one-by-one, unhooked mass airflow sensor, pulled out EGR valve and each time engine would stall. Check engine lite is on. Do you have any ideas?
Oct 29, 2008 at 12:45 PM
DLOBI
  • 125 POSTS
First step is to take it to the local repair shop or auto parts store and have them pull the code from the check engine light. Most places will do this at no charge. The indicated problem may solve your ticking.
Oct 29, 2008 at 2:44 PM
