1996 Oldsmobile Cutlass HELP
100,000 MILES • 6 CYL • FWD • AUTOMATIC
REDNECKF150
96 olds cutlass with 3.1 v6 fwd, the belt tensioner went out. So i replaced it, now when i go to pull out i just about have to press the gas pedal all the way down to pull out... But trans shifts smooth, this just happened all of the sudden.. any ideals?? thanks
Apr 2, 2010 at 11:13 AM
LEGITIMATE007
  • 5,121 POSTS
check the transmission fluid level and top off if need be, also take a look at the tps(throttle position sensor)
Apr 13, 2010 at 2:53 AM
