1996 Oldsmobile Cutlass gas gets in oil
JNLMEDOWS
Engine Mechanical problem
1996 Oldsmobile Cutlass 6 cyl Front Wheel Drive Automatic ? miles
how does gas get into oil .
drain oil leave plug out, with key on gas will run out of oil drain hole
Mar 29, 2009 at 2:35 PM
BLACKOP555
  • 10,386 POSTS
sounds to me like an issue with leaky fuel injectors.
how well is the vehicle holding fuel pressure with key off.
Mar 29, 2009 at 4:16 PM
JNLMEDOWS
turned out to be bad fuel pressure regulator intering thru vacum line thanks jr
Mar 30, 2009 at 1:48 AM
BLACKOP555
  • 10,386 POSTS
glad to hear you found your problem! must have been quite a torn diaphragm in the regulator.
Mar 30, 2009 at 11:07 AM
