1996 Oldsmobile Cutlass 1996 olds cutlass rough idle
1996 OLDSMOBILE CUTLASS
136,000 MILES • 6 CYL • FWD • AUTOMATIC
DEVO85
96 olds cutlass has rough idle
When driving hard, it does not miss a beat.
It doesn't appear to be starving for fuel.
When at curb idle if you raise the rpm to
4000 rpm the engine will cut out back and forth just
like you where turning the key off and on.
This happens exactly at 4000 rpm
Could it be TP Sensor?
Feb 16, 2009 at 8:49 AM
  • 110,244 POSTS
Hi:
Is the check engine light on?
Feb 19, 2009 at 5:43 AM
DEVO85
[quote:4568d82b61="Jacobandnickolas"]Hi:
Is the check engine light on?[/quote:4568d82b61]
Check engine light on-- only code was for O2 sensor
That sensor
has been replaced
Testing that I preformed is
1 Spark at coil packs
2 New plugs and wires
3 New air and fuel filters
4 EGR tests OK- clean with no carbon deposits
5 Bench tested TP sensor and mass air, both show they are working
6 Cleaned throttle body and idle control( idle control is working)
7 Checked all vac lines for cracks and soft spots
8 Fuel pressure tests showed pump pressure is within limits,filter not plugged,and regulator is working ok
9 Cyl compression readings where good with all cyl. readings very close to each other
10 Engine vac is 19 in
11 Checked all fuses and electrical connections
12 Brake booster vac ok--- holds vac--line is ok
13 Lower and upper intake gaskets replaced 6 mos
ago---I still checked uppers and they are good
14 Checked the new plugs, just to make sure I didn't
crack one putting them in
Next step will be going to Lowes to buy rope
Feb 20, 2009 at 4:57 AM
  • 110,244 POSTS
Hi:
Wow, you have done a lot of the work already. Have you inspected the crank sensor for damage or a broken wire?
Feb 20, 2009 at 5:34 AM
DEVO85
[quote:9bd28cfe06="Jacobandnickolas"]Hi:
Wow, you have done a lot of the work already. Have you inspected the crank sensor for damage or a broken wire?[/quote:9bd28cfe06]
Yes- I forgot to mention that I did check crank sensor
wiring. Appears to be ok
Is there a way to check sensor on car?
maybe through ohms resistance?
Feb 20, 2009 at 5:59 AM
