1996 Oldsmobile Cutlass
JESSEDESIREE16
  • 1996 OLDSMOBILE CUTLASS
  • 6 CYL
  • 148,000 MILES
It wont start the fuel in the fuel rail keeps recercalating with the key to the on posistion. Ive replaced the fuel regulator and fuel relay. Cant figure it out.
Saturday, October 16th, 2010 AT 11:43 AM
Pick your symptoms below check it and get back with some testing results
**Cranks but no start condition:
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine at least 3/16 away from ground -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, coil's resistances, distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it.
**No crank at all/nothing/nada when key is engage to starting position
Could be a blown fusible link, the starter, starter relay, park and neutral switch/transmission position switch and ignition switch assuming the battery and connections are good. Note:If it doesn't apply disregard.
Saturday, October 16th, 2010 AT 8:31 PM
