1996 Oldsmobile Cutlass
BIG DADDY TROUT 1
  • 1996 OLDSMOBILE CUTLASS
  • 6 CYL
  • 14,200 MILES
I have a bad vacuum hose going to the engine will that cause bad gas mileage? What is the name of the hose that goes to the engine block that is a small in diameter that I need to replace?
Sunday, November 23rd, 2008 AT 2:40 AM
  • 31,937 POSTS
Hi there,
Any vacuum leak will affect the fuel consumption, unfortunately I have no idea as to which vacuum hose you are referring to, if you are not sure what it is, drop into a mechanic and show then the hose and they will advise you.
Mark (mhpautos)
Sunday, November 23rd, 2008 AT 2:48 AM
