MY BELT MAKES A LOT OF NOISE AT CERTAIN TIMES. DO PULLEYS NEED OIL? , DO YOU THINK THE BELT SHOULD BE CHANGED?
IT NEVER WAS.
Oct 11, 2010 at 3:11 AM
WRENCHTECH
✓Experienced Mechanic
Your car doesn't have a timing belt. It has a chain. If your hearing a belt noise, it may be from the regular drive belt. Get a spray bottle with water and spray the belt with the engine running and see if it immediately stops indicating a belt problem.
Oct 11, 2010 at 3:31 AM
