1995 Oldsmobile Cutlass THERMOSTAT LOCATION ON CUTLASS CRUI
1995 OLDSMOBILE CUTLASS
JIGGYDUCHESS3
Heater problem
1995 Oldsmobile Cutlass 6 cyl Wheel Drive Type unknown Automatic 195K miles
THIS IS ON A 1995 CUTLASS CRUISER V6 3.1LTR.
I NEED A DIAGRAM OF THE MOTOR OR SOMETHING I HAVE FOUND THE HOSE WHERE THE THERMOSTAT SHOULD GO AND I AM WONDERING IF IT GOES WHERE THE HOSE CONNCETS TO THE METAL PIECE THAT BOLTS TO THE ENGINE OR WHERE THE METAL PIECE BOLTS TO THE MOTOR AS I WAS TOLD THAT NO OTHER GASKET GOES WITH MY THERMOSTAT. CAN YOU TELL ME WHERE EXACTLY IT GOES AT SO I CAN HAVE HEAT?
Feb 1, 2008 at 9:35 AM
MASTERTECHTIM
  • 4,750 POSTS
yes follow the upper radiator hose to the engine, the piece it connects to is the thermostat housing, it has 2 bolts holding it to the intake manifold. remove the 2 bolts and your thermostat is under there. hope this helps
Feb 1, 2008 at 9:59 AM
