1995 Oldsmobile Cutlass temp gauge stuck in hot range at al
JNEAL78
Engine Cooling problem
1995 Oldsmobile Cutlass 6 cyl 184000 miles
bought car with blown head gasket,replaced both head gaskets,thermostat,temp sensor, car runs pretty good but can't get gauge to act right
Mar 19, 2010 at 5:26 PM
  • 75,988 POSTS
I've looked for an engine coolant temperature gauge sender/switch but nothing for yours -I believe the CTS gives the temperature to the temp. gauge-double check the wiring to and from if okay could be the gauge itself out of calibration
Mar 19, 2010 at 5:41 PM
