1995 Oldsmobile Cutlass PS Pressure hose
198,800 MILES • 6 CYL • 2WD • AUTOMATIC
RPANCORBO
I've been trying to replace the Pressure hose but the nut on the back of the hose seems impossible to turn, is there any special tools required? would yo recommend a novice (myself) to replace the transmission ?
Jan 18, 2009 at 8:08 AM
  • 110,248 POSTS
Hi:
The only recommendation I can give you is to use a line wrench. As far as the trans, if you have never done it before and have no help from someone with experience, I wouldn't do it without a GOOD repair manual that provides step by step instructions with pictures to help identify parts.
Jan 26, 2009 at 9:03 AM
