1995 Oldsmobile Cutlass Light Bulb
75,000 MILES • 4 CYL • 4WD • AUTOMATIC
SOCCERRULZ1281
How do u change a tail light bulb on a 95 Oldsmobile Cutlass Ciera?
Mar 6, 2010 at 8:31 AM
  • 110,248 POSTS
Open the trunk and remove the carpet covering the tail light assembly area. Behind it will be wing nuts that hold the assembly to the car. Remove the nuts and the assembly will come off so you can access the bulb.
Mar 10, 2010 at 1:34 AM
