1995 Oldsmobile Cutlass Help
1995 OLDSMOBILE CUTLASS
TDCRTCHR
Transmission problem
1995 Oldsmobile Cutlass Four Wheel Drive Manual
I have a 95 oldsmobile cutlass. It runs good. But yesterday i started hearing a small noise under the hood. As i was pullin out the driveway i heard a noise pop like something had came loose. It started making a louder rattling noise and then when i press the gas and would barely move. It was in drive but the car would not accelerate and barely accelerates, wont move. It will not reverse. I can still turn it if someone pushed my car. It would even crank. What is the problem?
Dec 1, 2009 at 1:13 AM
JDL
  • 16,098 POSTS
Welcome to the forum, can you see anything wrong under the hood? Are you still OBD1 compliant? Check trouble codes. If it cranks good but won't start, have a helper crank it, while you check for spark at the plugs. If you have spark everywhere, use a gage and check fuel pressure. What's the engine size?
Dec 1, 2009 at 1:55 AM
