1995 Oldsmobile Cutlass HARD SHIFT INTO REVERSE AND DRIVE
99,000 MILES • 6 CYL • FWD • AUTOMATIC
LOUIS A. PERRY
RECENTLY THE CAR BEGAN TO THUMP HARD WHEN AT A STOP AND PUT INTO DRIVE OR REVERSE. AT TIMES IT ALSO SHIFTS HARD FROM FIRST TO SECOND GEAR. THE TRANSMISSION DOES NOT SLIP AT ALL, JUST A HARD SHIFT THAT GIVES A JOLT TO THE DRIVE LINE AND ENGINE MOUNTS.
SOMEONE TOLD ME THAT THIS COULD BE THE CV JOINTS AS THEY CUSHION THE TRANSMISSION.
CAN YOU GIVE ME ANY INFO? IS IT MORE LIKELY TO BE A CV OR SOMETHING ELSE?
THANKS.
Nov 19, 2009 at 4:16 AM
  • 110,244 POSTS
THe CV joints provide 0% cushion to the trans. Has the check engine light come on? Have you checked to make sure the trans and engine mounts are good?
Nov 28, 2009 at 5:00 AM
