i am looking for another fuse box on the car besides the one in the glove box?
SQUEEKS49
Electrical problem 6 cyl Two Wheel Drive Automatic 145000 miles
its a station wagon I am looking for possible blown fuses witch would have resulted in hooking batter up backwards.
What codes am I looking for how many blinks before I find out what the problem is? If the computer is responding how good of sign is that? The car turns over but wont fire could there be a different problem?
Nothing under the hood I need to get to the computer and start checking for power. If I check the coil pack for power what color wire would I check? I have checked for power there last time and I couldn't find any but that doesn't mean I was checking right but if the computer is sleeping than what?
Ok I have power to the coil pack and the fuse panel inside the glove box what should I look for now it still wont fire
Is there any specific way to check for power at the computer I have power at the coil pack and in the fuse box but still no spark maybe it is possible for it to be something else wrong?
Jun 27, 2010 at 4:27 AM
  • 55,594 POSTS
I have found some diagrams (below) that show the fuse box location which is on the passengers side dash panel and the identification for each fuse so you can get the problem fixed. Here is a guide that will help you as well.
Cheers, Ken
Jun 24, 2017 at 6:26 AM
VANCOUVERRICHARD
Thanks so much for posting this info. I have diff problems, my rear running lights are not working at night, my dashboard lights are off and horn doesnt work at all. These diagrams are very helpful tho and I now know where i can start with the Running lights issue. Hope its not the switch itself, headlights,turn signals and brake lights work, just not the running lights. May have to ask about the horn later tho. Thanks again tho, good place to start!
Jan 3, 2018 at 1:22 PM
  • 55,594 POSTS
Please post new questions here
Cheers, Ken
Jan 4, 2018 at 3:12 AM
