1995 Oldsmobile Cutlass drive train noise
1995 OLDSMOBILE CUTLASS
185,000 MILES • 6 CYL • FWD • AUTOMATIC
BILLPARTS
have a noise, sounds like a wheel bearing, but garage says no, could it be the drive axle or in the transmission? seems like its in the left front area
Sounds almost like the noise you hear going over the rumble strips at about 100 miles an hour
May 20, 2008 at 1:26 PM
  • 31,937 POSTS
Hi there,
As you can appreciate, it is a bit hare to pin point a noise with out hearing it. I would be guided by the mechanic, a wheel bearing will be easily picked up if run up on a hoist, as would a transmission noise. If in doubt, go get a second opinion first.
Mark (mhpautos)
May 20, 2008 at 5:24 PM
