1995 Oldsmobile Cutlass cololant in cylinders
155,000 MILES • 6 CYL • FWD • AUTOMATIC
MHAFEM
I found coolant in all the cylinders and a bad intake gasket. I replaced the intake gasket, and I still have the same problem. the coolant is clean and high in the intake ,also in the engine oil
Mar 2, 2008 at 12:27 AM
MERLIN2021
  • 17,250 POSTS
May have a head gasket problem, do a block test, this will sniff out hydrocarbons from exhaust fumes in the coolant...if so with a car this old, you might want to try this type of fix..
Mar 2, 2008 at 12:40 AM
