1995 Oldsmobile Cutlass Batery or starter
1995 OLDSMOBILE CUTLASS
MMMEME1968
Electrical problem
1995 Oldsmobile Cutlass 6 cyl Front Wheel Drive Automatic
my battery keeps going dead after driving around the block but later recharges itself after awhile.Alternator is charging. Also I keep blowing the fuse that allows the car to start.
May 10, 2009 at 3:21 PM
  • 110,240 POSTS
If the battery recharges itself, it is good. If you had the alt checked and it is good, then you have a short drawing power from the battery.
Here is a way to check for battery draw.
https://www.2carpros.com/first_things/why_is_my_car_battery_dead_over_night.htm
Let me know if it helps.
May 27, 2009 at 3:42 AM
