Saturday, March 27th, 2010 AT 9:44 AM
This car starts up and runs ok when cold but after it warms up it starts to run rough and will not take the gas off idle will try to stall but when over 2500 rpm runs ok but when it stalls it is very hard to start you have to give it all the gas. Things I have changed or checked map sensor this car has no mass air flow, idle air sensor, throtle position sensor, oxygen sensor, cam shaft position sensor, nock sensor, pvc valve, This problem started with hesitation only and moved to this
