Steering problem
1994 Oldsmobile Cutlass 6 cyl Front Wheel Drive Automatic 204K miles
We're replacing the inner and outer tie rods. The boot on the inner tie rod has what appears to be a plastic post that extends under a heat shield. We can't see where it goes or how it's connected, but it won't allow us to remove the boot. How do we disconnect it and remove the boot?
Sep 7, 2008 at 10:39 AM
