1994 Oldsmobile Cutlass Temperature variations
237,000 MILES • 6 CYL • 2WD • AUTOMATIC
DINGER01
My temperature varies according to the guage. I've replaced the thermostat, water pump, and flushed the system with a chemical flush. The temperature seems to go down with the increase of RPM's, and increase when I am idoling. The fans kick on after a few minutes. Any other ideas?
Aug 18, 2008 at 3:27 AM
2CARPRO JACK
  • 11,533 POSTS
Still may want to have the radiator power flushed, sounds like a flow problem, a partially plugged radiator can do exactly what you describe
Aug 19, 2008 at 12:57 AM
