1994 Oldsmobile Cutlass sputtering
DSTEDHAM
Engine Mechanical problem
1994 Oldsmobile Cutlass 6 cyl Automatic
This is my niece's car. When you start it, it sputters/coughs like it will go dead but it does not. The sputtering does not seem to have any effect on the running and it will go up a hill with no problem as if the sputtering is gone. The computer has been replaced but did not help the sputtering/coughing.
Thanks for any help yu can give.
Oct 23, 2009 at 4:06 AM
  • 110,248 POSTS
Has the check engine light ever come on? Have you checked fuel pump pressure? Has the fuel filter been replaced? When was the last tune up? Finally, is this problem there all of the time or does it go away after awhile?
Nov 18, 2009 at 4:07 AM
