1994 Oldsmobile Cutlass Keeps blowing fuses
1994 OLDSMOBILE CUTLASS
160,000 MILES • 6 CYL • FWD • AUTOMATIC
MEANDA16
My car keeps blowing the taillight fuse. I keep replacign it with the right fuse, a 20, and with one push of the brake the fuse will melt or blow. I think there might be a shortage somewhere but I dont know where
Feb 10, 2009 at 1:28 PM
JDL
  • CAR REPAIR CONTRIBUTOR
  • 16,098 POSTS
Hello, my info showed the brake lites and tail lites use a different fuse? Are you talking about the brake lites?
Your high mount brake lites are wired a little different than the lower brake lites. The lower brake lites are wired through the turn signal switch, the high-mount brake lites aren't.
Any testing you do, you might use a testlite across the fuse terminals, instead of a fuse, so you don't blow all your fuses. If the testlite comes on, the circuit is going to ground somewhere. If there is a connector in the trunk for the rear lites, unplug it, see if the testlite still comes on.
Feb 10, 2009 at 2:02 PM
