1994 Oldsmobile Cutlass Idling
LEAD2000
Engine Performance problem
1994 Oldsmobile Cutlass 6 cyl Automatic 46000 miles
When starting my car in the morning my car runs rough.Idles high then low almost stalling
Feb 2, 2009 at 11:31 AM
  • 110,248 POSTS
Hi:
Hs the check engine light come on? Have you checked for vacuum leaks?
Feb 19, 2009 at 6:59 AM
LEAD2000
check engine has come one twice
i found no vacuum leaks.
Someone said replace air idle control valve
Feb 19, 2009 at 12:08 PM
  • 110,248 POSTS
Hi:
It could be the IAC, but before you replace it, have the computer scanned at a nationally recognized parts store. Most will do it for free and then you will know if the IAC is bad or something other. That way you won't waste any money.
Have it scanned and let me know what you find. If the check engine light was on, there should be codes stored in the computer.
Feb 20, 2009 at 2:30 AM
