1994 Oldsmobile Cutlass idiot lights
1994 OLDSMOBILE CUTLASS
98,000 MILES • 6 CYL • FWD • AUTOMATIC
KELLY ISLAND
My 94 has been stuttering when gas was given to the engine I had the fuel filter replaced and a few days later the "Charge Battery" light came on the same day on the way home from work the ABS Light came on and the next morrning the Check Engine Light came one and the car begain to stall and misfire I was able to get back home and park it with in minutes of this happening. Any ideas one why this would happen?
Oct 28, 2009 at 4:34 AM
JDL
  • 16,098 POSTS
Welcome to the forum, thanks for the donation. I'd make sure the battery has a full charge, connections are good. Have the charging system checked. Then check for trouble codes. Around here, some of the national brand autostores will check codes. If your fully obd1 compliant, you can check codes your self. 12 pin datalink connector?
https://images.2carpros.com/forum/automotive_pictures/170934_aldl_30.jpg
You place a jumper between A & B terminals, turn the key to on position, no crank, just till dash lites come on.The check engine lite starts flashing, you count the flashes to get the codes. 94 and 95 are crossover years, sometimes the datalink connector is a hybrid?
Oct 28, 2009 at 6:47 AM
