Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Oldsmobile
Cutlass
Exterior Light
Headlight
Dimmer Switch
Replace/Remove
1994 Oldsmobile Cutlass have bright lights but the dim do n
1994 OLDSMOBILE CUTLASS
10,000 MILES • 6 CYL • 2WD • AUTOMATIC
BROADWAY21ST!YAHOO.COM
MEMBER
1 POST
i change the dimmer switch , but have no dim lights on car just bright llights
Feb 22, 2010 at 4:40 AM
Experienced Mechanic
Tan wire could be open
Do a continuity test on the tan wire between the dimmer switch and headlight wiring connector
Feb 22, 2010 at 5:04 AM
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
