1994 Oldsmobile Cutlass Had ignition moduale & fuel pum
MICHAELLEE2112
Electrical problem
1994 Oldsmobile Cutlass 6 cyl Front Wheel Drive Automatic
I took my car into a shop and had the ignition moduale replaced (you could see the one on the rgt. arching ),then was told the fuel pump didn't have enough pressure.I had them replace it. Now the guy at the shop says its noy running due to no spark, stating he now thinks its a cam sensor problem. I drove the car to the shop ( it was running rough but ran ). Any thoughts?? I really don't want to pay this shop any more for diagnostics. I was already going to spend 500$ on a 200$ car
Aug 11, 2009 at 9:30 AM
  • 75,988 POSTS
Hi and thank you for the donation
He's throwing parts to it-DON'T go back for more, go somewhere else
No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,cap and rotor /distributor pick-up coil, ignition control module, ECM,Ignitor camshaft and crankshaft position sensors- Note: If it doesn't apply disregard it
Aug 11, 2009 at 10:04 AM
