1994 Oldsmobile Cutlass fuel pump isnt getting any power
1994 OLDSMOBILE CUTLASS
CAITLIN123
Electrical problem
1994 Oldsmobile Cutlass Engine Size unknown Wheel Drive Type unknown Automatic 74000 miles
I have a 94 cutlass ciara,theres no power to the fuel pump could it be a blown fuse?and were would the fuse for the fuel pump be?
I already replaced the fuel pump, and the relay. There is power to the relay, but no power from the relay to the pump. Cannot find a fuse, or impact safety switch anywhere. Don't know source of the higher amp voltage that comes out of the relay and to the pump.
Mar 17, 2008 at 1:31 PM
Why don't you try the hard way 1st by checking the fuel pump connector gray wire for power all you got is 2secs to check when you hit the key to run- If its there direct power to the pump and see what happens-if it comes On-
Backtrack the troubleshooting to the fuel pump relay then to the computer.Meanwhile I'll go find the fuse-
I'll be back
Mar 17, 2008 at 1:50 PM
