1994 Oldsmobile Cutlass fuel pump
1994 OLDSMOBILE CUTLASS
90,000 MILES • 6 CYL • FWD • AUTOMATIC
SANDYBENNE1
There are times that the car will try to turn over, but sputters and dies. I try to start it again and it won't start, only floods. Then there are other times I go to start it and it starts right away, but starts to act like it's going to stop and then seems to get a breathe and then stops shaking and runs okay. I have replaced the fuel filter. Where exactly is the fuel pump and is it hard to change? I'm not sure this is the problem, but please help/ Thanks
May 14, 2009 at 9:29 AM
The fuel pump is in the fuel tank -you must check the fuel pressure with a guage to rule out the fuel pump
May 14, 2009 at 10:03 AM
