1994 Oldsmobile Cutlass Engine starts and idles fine, very
140,000 MILES • 6 CYL • FWD • AUTOMATIC
STOKESX25
My car engine starts and idles good. When accelerated it runs very rough, engine shaking. When it gets into high gear and car is running 40mph and above, engine runs fine. This just started happening one day and is very consistent, not intermittent. The engine runs rough hot or cold, it does not change. New spark plugs and wires installed less than a year ago.
Mar 15, 2009 at 4:25 PM
  • 75,988 POSTS
Get these sensors checked out throttle, mass airflow, and manifold absolute pressure also clean out the idle air control valve and EGR valve. Check the fuel pressure
Mar 15, 2009 at 9:28 PM
