1994 Oldsmobile Cutlass cutles is shifting in to lower gear
1994 OLDSMOBILE CUTLASS
162,000 MILES • 6 CYL • FWD • AUTOMATIC
GIZMO_48401
when i got the car about 6 mo ago i was toled it sometimes when it was cold would do what they called nutral slaming it self never herd of that latly it has been do this a lot is what it does is when driving it will shift it self to what seems to be a lower gear when it does this that spadomiter goes nuts and the rpm go really high around #4 the if i stop and try to go its like its in the lowes gear posibal and is hard to get it to go but gos really slow we just did a trans fluid and filter change and when it shifted to this lower gear iyou felt it its not as hard now but still doing it what couled it be
Sep 15, 2009 at 3:30 PM
  • 110,244 POSTS
Has the check engine light come on? It could be a sensor or a bad torque converter or front pump.
Sep 18, 2009 at 1:10 AM
