1994 Oldsmobile Cutlass caliper mount bolts (torx bolts)
SRAP
Brakes problem
1994 Oldsmobile Cutlass 6 cyl Front Wheel Drive Automatic
are the mounting bolts for caliper mount reverse thread....having trouble breaking them loose
Aug 17, 2009 at 5:07 AM
BLUELIGHTNIN6
  • 16,542 POSTS
hello and thanks for the donation!
the mounting bolts for calipers are not reverse thread. they are most likely frozen in the bushings. have you tried lubricating them well with WD40?
Aug 17, 2009 at 5:41 AM
SRAP
[quote:3d5608634e="bluelightnin6"]hello and thanks for the donation!
the mounting bolts for calipers are not reverse thread. they are most likely frozen in the bushings. have you tried lubricating them well with WD40?[/quote:3d5608634e]
Aug 17, 2009 at 6:41 AM
