1994 Oldsmobile Cutlass Brake Lights not working
89,000 MILES • 6 CYL • FWD • AUTOMATIC
BLUNDQUIST
Only my high center brake light works..The bulbs are all fine..I have already replaced the brake light switch and thats not the problem..Can anyone please help me with this problem, it would be greatly appreciated..Thank you in advance..
May 16, 2010 at 1:53 AM
BLUELIGHTNIN6
  • 16,542 POSTS
check your fuse(s) , if OK then the turn signal switch is probably at fault as the brake light circuit runs through the turn signal switch as well.
May 16, 2010 at 4:21 AM
BLUNDQUIST
bluelightnin6, thank you for your reply...I was wondering if that answer would still apply even though my blinkers are working fine...And, the fuses have been checked and are fine as well... thank you in advance for your help...
May 16, 2010 at 1:09 PM
BLUELIGHTNIN6
  • 16,542 POSTS
yes it would still apply, the internal circuitry of the turn signal switch that runs the brake lights may have failed, which would render the brake lights inoperative yet keep the signal lights working properly
May 16, 2010 at 4:11 PM
