1994 Oldsmobile Cutlass
KEITH_V
  • 1994 OLDSMOBILE CUTLASS
1994 Oldsmobile Cutlass 100000 miles
my friends car is 1994 oldsmobile cutlass ciera s, she was driving and her car wanted to die when she was stopped she would turn off her heat and then it didn't want to die. Her lights would go dim if she has to much stuff on ie heater, radio, volume of blower stuff like that. This would happen for about 3 to 4 days. I started her car this morning and it idle very high. It ran about 2 minutes and then it died. She also asked around they said it might be the voltage regulator. I think in the process of starting her car I think it is both any helpful hints I can do to see if it is the voltage regulator and/or alternater?
Saturday, March 8th, 2008 AT 8:48 AM
LEGITIMATE007
  • 5,121 POSTS
Yes it does sound like the alternator. The voltage regulator, now a days are inside of the alternator. So you will have to have that tested, but by what you are telling me it sounds like your alternator is going bad(regulator)
check it out and get back to us
Tuesday, March 25th, 2008 AT 1:19 PM
