1993 Oldsmobile Cutlass turn signals not working
ADRIAN_0089
Electrical problem
1993 Oldsmobile Cutlass 6 cyl Automatic 60000 miles
i recently bought a 93 cutlass supreme and the signals stopped working and rarely it would start working and go out the same day and when i press the brakes and try to use a turn signal the direction i try to put the signal to the light will not work on the side i try to use the signal for
Aug 28, 2009 at 7:08 PM
  • 75,988 POSTS
Check the turn signal flasher if okay, get the turn/hazard switch assy checked out-
Aug 29, 2009 at 9:19 AM
CAPT BILL
  • 6 POSTS
Hi - I took it to Gails Electric (not a gal by the way), in Costa Mesa, CA (about 15 miles south of Disneyland on the 55 Freeway for you out of towners). They are electrical repair experts - they pulled the dash off, traced the problem, it was a cracked wire and flasher both. Had me out of there in about 2 hours.
Sep 18, 2009 at 12:10 PM
  • 75,988 POSTS
I'm glad that you're on the road again and preventing an accident to occur. Good Luck
Sep 18, 2009 at 12:28 PM
