1993 Oldsmobile Cutlass Stalls
SETHDODD
  • 1993 OLDSMOBILE CUTLASS
Engine Performance problem
1993 Oldsmobile Cutlass 6 cyl Two Wheel Drive Manual
Have problem with car staying running. I have replaced battery, altanator, starter, and battery. I can drive the car for about a min, but as soon as I put it in reverse it dies out and takes about 15 mins to restart.
Tuesday, October 19th, 2010 AT 9:58 AM
JDL
  • 16,098 POSTS
With the restart, have helper crank, while you visually check for spark at the plugs. You can use a known good spark plug or spark tester, don't pull a spark plug. If you have spark everywhere, use a gage and check fuel pressure. Some of the national brand autostores used to loan out a fuel pressure gage. Also, any applicable mil codes?
Tuesday, October 19th, 2010 AT 11:29 AM
SETHDODD
I have already checked the fuel pressure and plugs and wire.
Tuesday, October 19th, 2010 AT 9:36 PM
