1993 Oldsmobile Cutlass need help
90,000 MILES • 6 CYL • 2WD • AUTOMATIC
PULSE08
i went to change my antifreez in my car now it will start but not go into gear... it does but wont move i dont know whats going on plz help
Dec 1, 2009 at 12:14 PM
HMAC300
  • 48,601 POSTS
if that's all you did was changed anti freeze, check the fluid level in the trans. It's possible that there was an interal leak in the radiator and got antifreze in the trans but i kind of doubt it. Probably just a freak thing that has happened. If the fluid is brown or looks dirty, it should look red, then have a trans guy look at it you may be looking at a rebuild.
Dec 20, 2009 at 12:26 PM
