1993 Oldsmobile Cutlass Lateral shuddering while driving
1993 OLDSMOBILE CUTLASS
154,000 MILES • 6 CYL • FWD • AUTOMATIC
UFANDERS
Hi Guys!
I've had this problem for several years now where my car shudders and makes a dull sound while driving, especially when in a sweeping turn, as on the highway. It varies with steering angle where in the steering dead spot I typically hear/feel nothing wrong, but when I make a left or right turn I get a periodic "thumpthumpthumpthump" sound and vibration.
I also get a pronounced shudder as I brake. I thought this was just warped rotors but I've had them ground a few times to no avail.
A friend said it may be a funky CV joint, and my talents lie in electronics, not mechanical systems so I haven't the slightest idea. =P
My car runs swell, though lacking power currently and I want to see it reach 250k miles. What should I do to correct this problem? I'm donating to the website for this answer.
Thanks!
Apr 14, 2008 at 5:19 AM
  • 55,423 POSTS
It sounds like your lower ball joints are bad, please inspect them ASAP. If a lower ball joint fails you can lose control of the car. Plus inspect the cv joints they can cause vibration while accelerating. Please let me know. :-)
Apr 14, 2008 at 8:18 AM
UFANDERS
Hooooly cow!
Yeah man, I'll have it in the shop tomorrow, Thanks for the heads up!
Are there any repair facility chains that you would recommend?
Apr 14, 2008 at 8:30 AM
  • 55,423 POSTS
np, it is difficult to recommend a repair garage, but soon we will have a system in place that will help you find one, so check back soon!
Apr 14, 2008 at 8:38 AM
UFANDERS
So I took my car to Precision Tune and they showed me that my balljoints and tierods on both sides were shot - there was grease piled up around them indicating, to their decree, that the seals were bad allowing grease to leak out and accumulate.
The parts cost slightly less than $400 with labor adding $280 more. I figure that this car has been so cheap to own thus far, it's worth abstaining from new car payments for another 6 months at least.
Do the repair guys seems like they're making a reasonable claim?
Thanks!
Apr 15, 2008 at 7:18 AM
  • 55,423 POSTS
yes, car repair is getting more expensive all the time. Take the current garage estamate and call other garages in the area to compare charges.
Apr 15, 2008 at 9:20 AM
UFANDERS
I got my car back from Precision Tune and there is no more shuddering while applying power to the wheels or during a turn. Very smooth indeed! I still have to get an alignment and I do have warped rotors, however. =P
The steering seems tighter, too.
Apr 17, 2008 at 4:27 AM
  • 55,423 POSTS
Good to hear!
Apr 20, 2008 at 5:35 AM
